Unexpected crash
AndyM1969
Anyone know what this means in the log, twice this has happened now, Lightwave simply shuts down without warning.
00:03:10 (0190.50) * OCTANE API MSG: denoiserThread0: CUDA_ERROR_ILLEGAL_ADDRESS: an illegal memory access was encountered. Restart required
00:03:10 (0190.50) |
00:03:10 (0190.50) | ++++++++++++++++++++++++++
00:03:10 (0190.50) | +++ IPR RENDER FAILURE +++ processing the failure callback
juanjgon
This seems a problem with the denoiser running out of memory. If you have several GPUs, you should configure the denoising only in the GPU with more memory (if they don't have the same memory) and never in the display GPU, which usually has less free memory. You can configure the GPUs using for denoising in the plugin options panel.
AndyM1969
Interesting, yes I do have multiple GPU's all identical, same brand and model but none of the scenes this has happened to have denoiser enabled.
Return to “Lightwave 3D”
