OctaneRender™ 2020.2.3
abstrax
Hi all,
This is a quick bugfix release 2020.2.3 to sort out some easy to fix but annoying problems found in 2020.2.2. Apologies for the hassle of having to update again.
You can find an overview of the changes between 2020.1.5 and 2020.2 in the release notes of 2020.2.
Make sure to use a NVIDIA Studio driver with version at least 456.38 on Windows or 455.23 on Linux to use this version. No driver updates are required for macOS 10.13 (CUDA).
This version supports the NVIDIA Ampere architecture (compute model 8.x) on Windows and Linux. As a consequence, Kepler GPUs with a compute model lower than 3.5 are only supported on macOS (which doesn't have Ampere support) and needed to be discontinued on Windows and Linux.
Changes since OctaneRender 2020.2.2:
Bugfixes:
  • Fixed missing render update if a toon ramp is modified.
  • Fixed superfluous geometry updates when an input of a volume node got changed.
  • Fixed specular transmission "leaking" into the indirect reflection render pass.
  • Fixed crash when you authenticate more than once in a session.
  • Standalone: Fixed crash when rendering a geometric primitive that just had at least one of its inputs collapsed into its pin.
Downloads
Downloads for Enterprise subscription users:
OctaneRender Enterprise 2020.2.3 Standalone for Windows (installer)
OctaneRender Enterprise 2020.2.3 Standalone for Windows (ZIP archive)
OctaneRender Enterprise 2020.2.3 Standalone for Linux
OctaneRender Enterprise 2020.2.3 Standalone for macOS (CUDA)
OctaneRender Enterprise 2020.2.3 Node Windows (installer)
OctaneRender Enterprise 2020.2.3 Node for Windows (ZIP archive)
OctaneRender Enterprise 2020.2.3 Node for Linux
OctaneRender Enterprise 2020.2.3 Node for macOS (CUDA)
Downloads for Studio subscription users:
OctaneRender Studio 2020.2.3 Standalone for Windows (installer)
OctaneRender Studio 2020.2.3 Standalone for Windows (ZIP archive)
OctaneRender Studio 2020.2.3 Standalone for Linux
OctaneRender Studio 2020.2.3 Standalone for macOS (CUDA)
Demo downloads:
Happy rendering
Your OTOY team
funk
Thanks team. We appreciate the quick fixes
ralf_breninek
Somehow the "OctaneRender Enterprise 2020.2.3 Standalone for Windows (installer)" does not seem to be working on Windows 10. The EXE does not seem to be doing anything. Any ideas?
C4D R21.207 / Octane for C4D 2020.2.4 / Watercooled 4 x EVGA Geforce RTX 2080 ti
http://www.pixelasm.com
Interface and motion graphics design for interactive interfaces and animations on TV, web, mobile and automotive from Köln / Cologne Germany
Please take a look
viewtopic.php?f=30&t=77459
ralf_breninek
aoktar wrote:Please take a look
I suppose you were not referring to my question or maybe the link was wrong? As the link covers the topic "Triplanar mapped bump problem - gamma issue?"
shenl9024
we need cinema 4d S24 of octane
shenl9024 wrote:we need cinema 4d S24 of octane
viewtopic.php?f=85&t=77426
funk
BUG: Regression in transform node breaks projections
There seems to be a regression caused by transform nodes that breaks projections.
The attached orbx renders fine in 2020.1.5, but breaks in 2020.2.3
1. Load the attached orbx in 2020.2 and select the rendertarget to start rendering. Notice the sphere has no texture in 2020.2.3!
2. Select the "test" nodegraph > rgb image
3. Change the UV transform > scale Z to 1 instead of 0. It now renders like 2020.1.5
linograndiotoy
Is that a real issue?
The default values for Scale, for all Transform nodes, is 1. In this specific case a 2D Trasnform node should be used, which only offers X and Y transform options.
funk
Lino unfortunately this node graph is generated automatically by the modo plugin when converting modo's own projections. The user has no control over it.
It works in all previous Octane versions though, so I don't see a good reason for breaking it.
Users with existing ORBX exports would need to manually edit every transform node that has this issue.
