Can someone help me to understand all infos on render window
HHbomb
Hi, there is more and more infos but I don't know what it means... :oops: ( see image below )
Creative_Sheep
Well some are your CPU, GPU Memory size, resolution of the render and estimated time it will take to complete the render.
HHbomb
Thanks Creative_Sheep.
But I mean : (see pict)
rd: 19/32
new: 39
cop: 33
disc: 6
conv: 33
blit: 33
Perhaps it would be helpfull to know.
neonZorglub
Hi HHbomb,
Those special statistics are displayed when you turn on "Enable Extra Render stat info" in Octane Preferences / Trouble Shooting.
Those are more intended for debugging, but could give some hint in case of issues.
rd: valid render count / converted image count
new: new image count, from render engine
cop: images copied from engine to render buffer
disc: images discarded
conv: images converted from render buffer to blit buffer (rgba..)
blit: images copied from the blit buffer to the visible viewport
When changing parameters, materials, etc while the render is in progress, the current rendered image is sometimes discarded, as a new render is restarted.
Some changes affect only the render buffer, like Exposure of Imager, so you will see those numbers increase, but the render steps from geometry will not change (smp/px)
Some parameter change should have no effect (like the motion blur duration when motion blur is disabled), and nothing should change..
So, it can give an indication on how a parameter change affect the current rendering.
glimpse
neonZorglub wrote: Those special statistics are displayed when you turn on "Enable Extra Render stat info" in Octane Preferences / Trouble Shooting..
thanks for all the info!
HHbomb
Thanks NZ. I don't understand all but it can give some clues.
Return to “Autodesk 3Ds Max”
