Octane Hydra | Solaris plug-in 2020.2.1.2 - 03-26[OBSOLETE]
BK
Dear Octane community,
OTOY® is proud to announce the availability of the new DCC plugin OctaneRender Hydra | Solaris V2020.2.1 - for Houdini 18.5.499.
The world's fastest unbiased GPU rendering engine on CUDA and Metal now integrate completely with Houdini 18.5 Solaris.
What is Octane Hydra | Solaris?
The Octane Hydra | Solaris plugin is based on Pixar’s USD (Universal Scene Description) and Pixar’s Hydra API to empower artist workflows across look development, scene layout, lighting, and final rendering.
Pixar's USD pipeline
https://renderman.pixar.com/stories/pixars-usd-pipeline
-Installation steps-
Insert the OctaneRender® plugin folder path to the houdini.env file. Houdini®creates this file after launch it for the first time.
On Linux and macOS® systems, append a single line to enable OctaneRender®:
HOUDINI_PATH = "/path/to/octane;&"
On Windows® systems, you need to set the PATH to point to the plugin bin folder as well:
PATH = "C:/path/to/octane/bin;$PATH"
Setting this environment variable outputs any error related to loading the OctaneRender® plugin on the command line for diagnosing installation problems:
HOUDINI_DSO_ERROR = 2
- Changes since first beta II-
  • Matched with the main Octane Houdini plugin version 2020.2.1.2
  • Added Octane attributes in the Render setting nodes
  • Improved refraction/transparency
  • Bug fixes
-Known Issues-
- Light Linker is yet to be supported as we are investigating if we could assign the Octane light IDs internally.
- we are still experiencing issues with Octane nodes working correctly due to what appears to be issued with the version of USD that Houdini is built with.
Enterprise Subscription Downloads
2020.2.1.2 Houdini 18.5.499
Studio Subscription Downloads
Happy GPU Rendering !!
Your team
OTOY
Kind Regards
bk3d
