OctaneRender™ for Blender 2020.2 - 23.4 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Enterprise License Holders.
Important Note: This version has reverted to version OctaneRender 2020.2, due to issues identified with the 2020.2.1 integration. This version still uses Blender 2.92, and we will be seeking to reintegrate OctaneRender 2020.2.1 in the very near future.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Reverted SDK to 2020.2
  • Supported the Octane AOV feature
FIXES SINCE LAST RELEASE
  • Fixed the crash when using the Object Data node with an Empty
  • Fixed the crash when opening "Octane DB" during the final rendering
  • Fixed the opposite rotation issue
  • Fixed the extra "recreate mesh data" for the hidden objects when exiting isolation mode
How to use the AOV feature in the OctaneBlender
You can also find an AOV sample here:
AOV_Sample.blend
(2.12 MiB) Downloaded 342 times
You can read about new features of OctaneRender™ 2020.2 here:
viewtopic.php?f=24&t=76901
Make sure to use a NVIDIA Studio driver with version at least 456.38 on Windows or 455.23 on Linux to use this version. No driver updates are required for macOS 10.13 (CUDA).
1. OctaneRender™ Server
Windows
Blender Octane Edition - 23.4 (2.92)
Octane Server - Enterprise Edition - 23.4
Linux
Installation:
$ OctaneServer &
DOWNLOAD
macOS (CUDA)
DOWNLOAD
