Macbook pro 15. 2013 late
HardMax5
hi there , I want to know how to get octane render running on old MacBook Pro 15 2013 late .
I want to buy this ASUS DUAL AMD RADEON RX 5500 XT EVO, 8GB, GDDR6 - DUAL-RX5500XT-O8G-EVO
could it make octane render work on my Mac ?
please help ?
sorry MacBook Pro 15 Late 2013 is too old, and it should be equipped with a GTX 750M Nvidia GPU, so not usable with OctaneX.
But since it has Thunderbolt 2, please have a look at here:
https://github.com/mayankk2308/purge-wr ... eparations
And here:
https://github.com/mayankk2308/purge-wr ... d-Handbook
Please also note that in OctaneX, the AI Denoiser is performed via CPU, not GPU, but you should need a CPU from 2015 or newer for performing AI Denoiser with OctaneX.
Older CPUs do not have the necessary instructions for AI Denoiser.
ciao Beppe
HardMax5
hi there , thanks for replaying ,
just want make sure you mean if I get this GTX 750M Nvidia GPU, could make it run , but I still will have CPU problem cos too old still ,right ?
so there is any option for the cpu problem , also I search for the GTX 750M Nvidia GPU but too many there , please do you have any link for that with cheap price?
sorry for many questions just trying to understand this better !
thank you very much ! :D
With Nvidia GTX 750M, you can use Octane CUDA Mac, but only under High Sierra 10.13.6, since Nvidia has stopped to support CUDA after that Mac Os version.
Please also note that GTX 750M performs only ~9 in Octanebench, while we suggest a minimum of ~45 for a smooth experience:
https://render.otoy.com/octanebench/sum ... 1x+GT+750M
In addition, the internal GPU is already heavily tasked by system and monitor, leaving only few MB of VRAM for rendering.
So you should need to enable the Out-of-core option in Octane preferences to move part of the scene from VRAM to system RAM.
You lose another 20% or rendering power, but you should be able to render very basic scenes.
On the other side, if you add a recent AMD GPU in an eGPU Thunderbolt 3 box with adapter for Thunderbolt 2, you can use the Nvidia GPU for monitor/system, and use the AMD GPU for rendering only, with decent speed.
Here are some preliminary results of the currently supported AMD GPUs under Big Sur 11.1:
- Radeon Pro Vega II Duo - 446 OB*
- Radeon Pro Vega II - 223 OB
- Radeon VII - 214 OB
- 5700 XT - 184 OB
- Vega FE - ~174 OB
- Vega 64 -~160 OB
- Vega 56 - ~126 OB
- Vega 48 - 117 OB
- 5600M - 117 OB
- 5500M - 83 OB
- Vega 20 - ~55 OB
- Intel iris 640 - ~ 17
- Intel iris 630 - ~ 15
Happy Mac GPU rendering,
ciao Beppe
