OctaneRender™ for Blender 2020.2.1 - 23.3 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Upgraded to 2020.2.1
  • Upgraded to Blender 2.92
  • Added new texture utility nodes(channel inverter, channel merger, composite layer...)
  • Added null material
  • Supported new color correction node
  • Supported OCIO color management in the octane preferences
  • Supported new Octane export with OCIO
  • Added the "OutRotation" in "Object Data", it can be used as the rotation for Falloff Tex or light direction
  • Supported animated "offset" for Octane Image Textures
  • Supported animated transforms in Scatter nodes(please use the newly added "OutTransformedGeo" output socket in such cases)
  • Optimized camera imager/post-process render when the universal camera is used
FIXES SINCE LAST RELEASE
  • Fixed the crash when using the Object Data node with an Empty
  • Fixed the crash when opening "Octane DB" during the final rendering
  • Fixed group node render issue
  • Fixed Manta gas render issue
  • Fixed instance color texture render issue
  • Fixed the inverse layer issue in the composite texture
  • Fixed the missing emission issue when changing the area light shape from "Square" to "Disk" in preview mode
  • Fixed command line render crash
  • Fixed probabilistic motion blur issue when the universal camera is used
You can read about new features of OctaneRender™ 2020.2.1 here:
viewtopic.php?f=24&t=77111
Make sure to use a NVIDIA Studio driver with version at least 456.38 on Windows or 455.23 on Linux to use this version. No driver updates are required for macOS 10.13 (CUDA).
1. OctaneRender™ Server
Windows
Blender Octane Edition - 23.3 (2.92)
Octane Server - Enterprise Edition - 23.3
Linux
Installation:
$ OctaneServer &
DOWNLOAD
macOS (CUDA)
DOWNLOAD
