octaneX pr7: materials opacity problem
tutu329
1、create an object
2、create a new oc material on this obj
3、add opacity with any texture
4、die
opacity may be the problem
2018 macbookpro 15(radeon pro 560x,c4d r23)
thanks a lot
tutu329
my case is:
new a oc material, then in its opacity channel add a texture like gradient, then c4d die , sometime Mac osx die
my osx is Big Sur 11.2.1
thanks a lot!
please avoid to use c4d shaders, and always prefer to use Octane shaders.
The only exception are C4D Gradient and Noise nodes that can be used, but you need to go to c4doctane Settings/C4D Shaders, disable the C4D Shader Baking, and enable only the Use OSL option:
ciao Beppe
