Problem with mixed material
andreashoelters
I´m trying to create a bottle label with a normal paper texture and then 2 different kind of metallic effects. I think i managed it to the point that in the mixed material I can show either or. But how do i show them with the same amoun(100%) on the bottle?
sorry the image is not visible, but you should need a black and white mask, like 100% black where the paper is, and 100% white where the metal is, and use it in the Amount pin of a Mix material, or Mask pin of a Composite material between paper and metal material, or in the Opacity pin of a Metallic Layer applied to the paper material.
ciao Beppe
