[Octane] Octane Render for Houdini. Build 2020.2.0.4 (Build date: Feb  8 2021 17:02:10)
[Octane] Octane API: 2020.2
[Octane] HDK API: 18.5.351
[Octane] Houdini host version: 18.5.351
[Octane] Initializing Octane API
[17:59:08.720]             Started logging on 03.03.21 18:59:08
[17:59:08.722]
[17:59:08.722]             Flag                      Type    Value      Prefix       Description
[17:59:08.722]             ------------------------- ------- ---------- ------------ --------------------------------------------------------------------------------
[17:59:08.723]             activation                release 1          "activation" Enables log events for activation
[17:59:08.723]             apiChangeMgr              release 1          "apiChngMgr" Logs ApiChangeManager::update().
[17:59:08.723]             apiExport                 release 1          "apiExport"  Logs all geometry export operations.
[17:59:08.723]             apiForceConnectChecks     release 1          "apiChecks"  Enforces validation of node-pin connections.
[17:59:08.723]             apiNetwork                release 1          "apiNetwork" Logs all important calls into ApiNetRenderManager
[17:59:08.724]             apiNodeSystem             release 0          "apiNodeSys" Logs all write operations in the API node system.
[17:59:08.724]             apiProject                release 1          "apiProject" Logs all important calls into ApiProjectManager.
[17:59:08.724]             apiRender                 release 1          "apiRender"  Logs all important calls into ApiRenderEngine.
[17:59:08.724]             appShutdown               release 1          "appShutdow" Dumps information about application shutdown
[17:59:08.724]             assetsFinder              release 0          "assetsFind" Logs assets uploaded to ORC
[17:59:08.725]             cacheLoad                 release 0          "cacheLoad"  Dumps information about the data cache load
[17:59:08.725]             compAlwaysSync            release 0          "compute"    Always commit the command buffer and wait after each shader queued.
[17:59:08.725]             cudaAlwaysSync            release 0          "cuda"       Enables synchronization after each kernel call
[17:59:08.725]             cudaNoKernelFlush         release 0          "cuda"       Disables the explicit flushing of CUDA kernel calls
[17:59:08.725]             daemon                    release 0          "network"    Not used.
[17:59:08.725]             deactivation              release 1          "deactivati" Enables log events for deactivation
[17:59:08.726]             disableOoc                release 0          "cuda"       Disables out-of-core.
[17:59:08.726]             disableRtx                release 0          "disableRtx" Disables RTX acceleration.
[17:59:08.726]             dongle                    release 1          "dongle"     Enables logging of the dongle activity
[17:59:08.726]             dumpAlembicObjects        release 0          "AlembicObj" Dump data about exported Alembic objects
[17:59:08.726]             enableOoc                 release 0          "cuda"       Enables out-of-core.
[17:59:08.726]             forceMetalViewport        release 0          "forceMetal" Force to use HDR metal viewport.
[17:59:08.727]             forceOocImages            release 0          "cuda"       When out of core is enabled forces ALL images to go out of core.
[17:59:08.727]             forceOocMeshes            release 0          "cuda"       When out of core is enabled forces ALL meshes to go out of core (overrides forceP2PMeshes)
[17:59:08.727]             forceP2PMeshes            release 0          "cuda"       When P2P is enabled forces ALL meshes to use peer-to-peer memory
[17:59:08.727]             heartbeat                 release 0          "network"    Enables logging of the network rendering heartbeat.
[17:59:08.727]             hideOslEditor             release 0          ""           hides the OSL editor.
[17:59:08.727]             imageSaving               release 1          "imageSavin" Logs saving of render images.
[17:59:08.727]             licenseUsage              release 1          "licUsage"   Release logging flag for inter-process license usage
[17:59:08.728]             liveDBDebugging           release 0          "liveDB"     Logs information about the download process for debugging purposes
[17:59:08.728]             logAppendToFile           release 0          ""           If enabled, logging will be to the already existing log file appended
[17:59:08.728]             logFlags                  release 1          ""           If enabled, all log flags will be dumped during startup
[17:59:08.728]             logFlushTime              release 100        ""           The time (ms) after which the log is flushed. If set to 0, the timer based flush will be disabled.
[17:59:08.728]             logForceFlush             release 1          ""           If enabled, every logged line will be flushed
[17:59:08.729]             logJuce                   release 0          "JUCE"       If enabled, JUCE logging will go through the logging framework of Octane
[17:59:08.729]             logPrefix                 release 1          ""           If enabled, each log line will have a prefix
[17:59:08.729]             logTime                   release 1          ""           If enabled, each log line will have a timestamp
[17:59:08.729]             logToDebugConsole         release 0          ""           If enabled, logging will go to the debug console (Windows only)
[17:59:08.729]             logToFile                 release 1          ""           If enabled, logging will go to a log file
[17:59:08.729]             logToStdout               release 1          ""           If enabled, logging will go to standard out (when set to 1) or standard error (when set to 2)
[17:59:08.730]             makeAllInspectable        release 0          "geometryAr" If enabled, all geometry archives become inspectable. Should only be used if you know what you are doing.
[17:59:08.730]             moduleData                release 0          "moduleData" Logging for the loading/storage of module data
[17:59:08.730]             moduleLoader              release 0          "loader"     Logging for module loading and unloading.
[17:59:08.730]             navigateWhilePaused       release 0          ""           If enabled, camera changes will still be allowed while rendering is paused. The viewport will not update of course.
[17:59:08.730]             netRender                 release 0          "netRender"  General logging of network rendering
[17:59:08.730]             oocRamLimit               release 0          "cuda"       Sets the out-of-core RAM limit in MB.
[17:59:08.730]             optixDisableCompaction    release 0          "optix"      Disable OptiX data compaction
[17:59:08.731]             optixDisableUpdates       release 0          "optix"      Disable OptiX data updates
[17:59:08.731]             profEvents                release 0          "profile"    Enables logging of detailed profiling information
[17:59:08.731]             rdCacheDelay              release 0          "rdDataComp" Allows you to provide a msec delay >0 before caching begins.
[17:59:08.731]             rdNoFastBuild             release 0          "rdDataComp" Disables fast building of the render data (for testing purposes)
[17:59:08.731]             rdNoRamp                  release 0          "rdTarget"   If set, it disables the initial ramp up of the work chunk sizes.
[17:59:08.732]             rdStart                   release 1          "cuda"       Logs information about the creation and start up of render devices and threads.
[17:59:08.732]             stats                     release 1          "stats"      Enables logging of the statistics
[17:59:08.732]             subdivider                release 1          "subdivider" logs info about the subdivision process
[17:59:08.732]
[17:59:08.732]             OctaneRender Enterprise 2020.2 (10021201)
[17:59:08.733]
[17:59:31.023] cuda      : device 0: constructing with ID 0, name 'GeForce RTX 2060 SUPER', thread (nil)
[17:59:31.083] apiChngMgr: finishing update
[17:59:31.086] apiChngMgr: finishing update
[17:59:31.093] apiChngMgr: finishing update
[17:59:31.115] apiChngMgr: finishing update
[17:59:31.130] apiChngMgr: finishing update
[17:59:31.144] apiChngMgr: finishing update
[17:59:31.574] apiNetwork: enabled network rendering
[Octane] Network rendering enabled from hython automatically
[Octane] Network rendering: Enabled
[Octane] WARNING: preferences file not found: /home/vime/houdini18.5/octane.prefwe are loosing about 20 seconds while calling hython from commmand line on Ubuntu 20.04 (see the log).
I am pretty sure that this happens because it tries to activate Network Rendering. How can I deactivate that using hython?
