Not Render in Picture Viewer
t12chat
I'm using the latest version of Octane. Cinema4D R20.
I made a scene with X Particles and Rendered with Octane. Everything is fine in Live Viewer but when i'm trying to render in picture viewer all the frames are the same. Only watch the first frame. I made a little research and i disable the xp cache, but i have the same problem.
Is something with Object Tags?
What should i do?
please, open the scene, then go to c4doctane Settings/Other tab, and, at the bottom of the panel, enable all the Log option checkboxes.
Then, load the scene in Live View, then in Picture Viewer, or until crash, then reopen c4d, navigate to c4doctane Settings/Other tab, press the Generate log report button, and share the octanelog_report.zip file, thanks.
Please also share a screenshot from render Settings/Octanerender main tab, thanks.
ciao Beppe
t12chat
An octane Log Report and a screenshot with main render settings.
(141.54 KiB) Downloaded 184 times
thanks for your collaboration.
Please upgrade to c4doctane 2020.2-R3.
You can find it by visiting your personal Downloads area too:
https://render.otoy.com/account/download_archive.php
If not enough, please compress and share the scene with me here or via Private Message, thanks.
ciao Beppe
thanks for sharing the scene.
The issue was caused by an incorrect setting of the FPS of the scene, Render Settings was set to 30, while the Project was set to 29 FPS:
After correcting it to 30, the scene is rendering correctly also in Picture Viewer:
ciao Beppe
