Shortcut for Solo/disable node and favourite nodes
KeeWe
I have 2 workflow improvements:
1) Shortcut or toggle button for solo and siabling nodes. It's kinda tedious to use via the context menu.
2) I'm using VFX Console from videocopilot on a regular basis in After Effects, hence the idea. When pressing tab or between to nodes, it would be nice to have 5 or 10 customized favourite nodes right away. I guess its a little bit more work to implement it but maybe it's something worth considering for future builds. :)
Cheers!
6850k // 32 GB // 1080, 1080 Ti, 2080 Ti // Win 10 // C4D 19.068
What kind of customised nodes? Single node or grouping the a few?
KeeWe
Well, in a first step it would be vera handy to specify some nodes which the are used the most. For instance: If I use the color correction, custom OSL, multiply and noise very often it would be a huge timesaver if these nodes (which the user speicified himself) would be availaible instantly when pressing tab. So there would be no need of typing.
As I said, it would be the same functionality like VFX console, you can take a look here:
https://www.youtube.com/watch?v=rqmDo04T0pY
You can save some parts as presets and get back
Return to “User requests”
