Cache issues
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
J.C
I've noticed that "SELECT" object strategy is not working.
Clearing cache does not work properly. The object is not being reloaded after clearing the cache.
To update object in most cases going to edit mode helps to reload mesh.
System – Windows 11
linograndiotoy
I'll check!
linograndiotoy
Both Edit and Select modes (I definitely prefer the first method) are working fine here.
Do you have content and steps showing Select mode doesn't work to clear the cache?
Clear Cache is also working fine here.
J.C
Here are the steps to reproduce.
Create a spline, add depth to it, render. Stop render. Change spline shape. Exit edit mode. Render.
Only entering edit mode during rendering helps to render modified shape. Clearing cache clears the cache but when not rendering.
System – Windows 11
linograndiotoy
I've set the Object Type to Reshapable and everything works as expected.
Return to “Bug Reports”
