Text strings conflict with another plugins
SSmolak
I noticed why Octane always loose its file menu text string to StrNotFound. There is conflict with another plugins which use its own strings descriptions like MeshBooleans and many other :
STRINGTABLE meshboolean
meshboolean "Mesh Boolean";
SETTINGS "Default Settings";
This additional StringTable in another plugins cause Octane file menu problem.
What's mesh boolean?
SSmolak
aoktar wrote:What's mesh boolean?
It's example of plugin ( https://www.thegreatsummit.com/product/meshboolean ) which use own strings descriptions which interfere with Octane text strings.
SSmolak
Generally any plugin which has such description folder structure cause problem with Octane text string :
Can you please post whole log output from "Console" window? Find under Extensions/Console menu.
SSmolak
Loaded Octane DLL:OctaneRender Enterprise 2020.2 version:10021201 SDK:2020.2
OctaneRender for Cinema 4D 2020.2 built for:230 C4D vers:23110
C4D:23110 comp:[I7-6850K] OS:[WINDOWS 64 BIT] Windows 10, 64 Bit, Professional Edition (build 19042) versType:10
CPU:[GenuineIntel, stepping 1, model 15, instruction family 6] speed:3.6 GHz numOfCpu:12Ht
Plugins:[houdiniconfig addons advanced_render alembic archigrass bitmapfilter bpexchange browser bugslife_client c4d_viewport_render c4dOctane-R23 ca ca2 cadexchange clothilde collada14 collada15 colorchoosergui compositing deltamush deployment dwg dwgobjects dynamics exchanges expressiontag fbx gltf goz hair houdiniengine i_skp interop io_obj metrics mkmodeler mocca model mograph motioncam motiontracker nbo nbp newman nodeeditor objects onlineupdater projectassetinspector python relaxuv sculpt sculptbrushes shader sketch sky sla spacemouse substance teamrender thinking_particles tpoperators usd uvviewport volumes xpressocore xtensions ]
NVAPI initializing...
NVAPI Version: NVidia Complete Version 1.10
Nvidia driver version:461.4 [r461_36]
Loaded 174 osl scripts from dir:G:\Maxon Cinema 4D R23\plugins\c4doctane\res\osl_scripts
After running Octane :
delete file:bugreport_20210127_015407.zip
Creating zip file:C:\Users\smola\AppData\Roaming\Maxon\Maxon Cinema 4D R23_EB6100C3\_bugreports\octane\bugreport_20210209_222137.zip
Adding file:C:\Users\smola\AppData\Roaming\Maxon\Maxon Cinema 4D R23_EB6100C3\c4doctanelog.txt
Deleting texCache folder... C:\Users\smola\AppData\Local\OctaneRender\cache\texCache
VRAM used/free/max:0Kb/11Gb/11Gb Out-of-core used:0Kb RAM used:9.449Gb total:63.901Gb OpenGL free/total:0/0
Scene created in plugin version 10021000
Scene plugin version is older than version:2020.2
Plugin will convert the parameters of displacement texture.
Animated attributes should be changed by manually!
File not found:C:/Users/smola/AppData/Roaming/Maxon/Maxon Cinema 4D R23_EB6100C3/updates2020.txt
Python :
Traceback (most recent call last):
File "scriptmanager", line 3, in <module>
ModuleNotFoundError:No module named 'urllib2'
I removed all plugins only Octane and MeshBoolean are installed
SSmolak
Problem was resolved by MeshBoolean developer. There was bug in their plugin. They sent me new version and problem with Octane file menu is gone.
frankmci
I've wondered about this for ages, and just accepted that the menu was out of whack on our machines since it didn't seem to cause any functional problems. I figured it was from a plugin, but never spent the time to track it down to MeshBoolean. Thanks for doing the legwork to figure it out.
