OctaneRender™ for Blender 2020.2.RC7 - 23.0 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Upgraded to Blender 2.91.2
  • Upgraded to 2020.2.RC7
  • Supported the new scatter tools(please check the attached sample)
  • Supported Blender internal OpenVDB Fluid
  • Supported to paint Octane image texture nodes
  • Supported to use Octane style node menu
  • Optimized camera imager/post processing rendering
  • Optimized node graph upload - do not upload unreachable nodes
FIXES SINCE LAST RELEASE
Here is a sample of the new scatter tool feature:
You can read about new features of OctaneRender™ 2020.2 RC7 here:
viewtopic.php?f=33&t=76774
Please note that 2020.2 RC7 is still not a production build, so please do not use it for production purposes.
Make sure to use a NVIDIA Studio driver with version at least 456.38 on Windows or 455.23 on Linux to use this version. No driver updates are required for macOS 10.13 (CUDA).
1. OctaneRender™ Server
Windows
Blender Octane Edition - 23.0 (2.91.2)
Octane Server - Enterprise Edition - 23.0
Linux
Installation:
$ OctaneServer &
DOWNLOAD
macOS (CUDA)
DOWNLOAD
