Hi all
My Palit gtx 460 is running at 70 - 75 degree's under full load. Is this normal?
120mm front and rear fan. Two side holes.
Cheers
J
GTX 460 running hot
GTX670 4GB, GTX460 2GB, Q8400 2.27Ghz, 6GB RAM
Yes, mine too.
Put another 120 mm on the side (preferably blowing directly on the card) - I lowered the temp from 76 to 71 max., by doing so.
cgmo.net
cgmo.net
Mine is running up to 98 degrees C at full load. Don't worry about 75 degrees.
- Jaberwocky
I think the ceiling is 104 deg c on the 460.
When you hit 100 deg C then it's time to start blowing hard into the machine to cool it.
Anyone tried undervolting it using afterburner to around .875 Volts ? That should knock a few degrees off the temps provided you haven't over clocked it.
Now I am plugging in my Monitors into the lowest GPU (wich gets most air). So you can save some degrees.
ya one of my 550s is also running at 98 degrees CRefracty wrote:Mine is running up to 98 degrees C at full load. Don't worry about 75 degrees.
Regards
Nehale
Windows 10 x64 | 2x GTX680 | i7 990X | 24GB
Cinema 4D R17 Studio + 3Ds Max 2017
OctaneRender™ for Cinema 4D 3.01 + OctaneRender® for 3ds max® v3.14
Nehale
OK sweet thanks!!!
Refracty: Whats your mobo? 4 cards is pretty sweet!!!
Hi 3form,
I am running the cards on a ASUS Rampage Extreme III.
Cheers
Refracty
Cheers
Refracty
