different UV maps with displacement on
- BorisGoreta
- Contact:
When displacement is used in a surface all texture nodes use the same UV map as the displacement node. Usually I can set 3 different UV maps for other texture nodes.
19 x NVIDIA GTX http://www.borisgoreta.com
- BorisGoreta
- Contact:
For some reason if the displacement map is the the first UV map then other texture nodes can use UV maps 2 and 3.
