$F variable not recognized?
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
doca
I'm on Windows 7 with Houdini 18.5.351 with Octane 20.1.5.3.
Trying to render a sequence and only single file being written and overwritted.
This is my Image file path/prefix:$HIP/render/$OCTANE_PASS.$F
Any clue?
Thanks.
juanjgon
Can you please try with $HIP/render/$OCTANE_PASS-$F to check if it helps? I've seen problems before while using "." and "_" between variables.
galleon27
Had this problem when rendering png sequences. Adding the extension (.png, .exr) fixes this problem.
juanjgon wrote:Can you please try with $HIP/render/$OCTANE_PASS-$F to check if it helps? I've seen problems before while using "." and "_" between variables.
Houdini doesn't play well with hyphens. This is from their documentation:
"Do not use a hyphen to separate the frame number from the name (for example frame-$F.pic). MPlay will interpret the resulting filenames (frame-1.pic, frame-2.pic, frame-3.pic, and so on) as containing negative frame numbers (-1, -2, -3, …)."
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
doca
Thanks Galleon,
That sorted things out.
@Juan might be worth setting better defaults or updating houdini doc pages with this info?
Cheers.
Return to “Bug Reports”
