OCTANE + CINEMA 4D, BIG SUR CRASHES ALL THE TIME - WHY?
skf
I have an imac 2020 with AMD Radeon Pro 5500 XT 8 gb Cinema 4d r23 and trial version of octane. Every third time , when i open material node editor cinema crashing https://prnt.sc/x2ey9o ((
Help me please!
please, open the scene, then go to c4doctane Settings/Other tab, and, at the bottom of the panel, enable all the Log option checkboxes.
Then, load the scene in Live View, then edit the materials in Node Editor until crash, then reopen c4d, navigate to c4doctane Settings/Other tab, press the Generate log report button, and share the octanelog_report.zip file, thanks.
ciao Beppe
skf
Thank you for ur answer Beppe ˆ)
Here the link to octanereport files:
https://www.icloud.com/iclouddrive/0b5K ... log_report
skf
Did u review my logs? ˆ)
I think we need to wait for PR8 for this kind of errors, it shouldn’t be too far away.
ciao Beppe
skf
Thank you!
And what do u mean? Pr8 what is it?
anthonyhague
I'm running iMac (Retina 5K, 27-inch, Late 2015), 4 GHz Quad-Core Intel Core i7, 32 GB 1867 MHz DDR3, AMD Radeon R9 M395X 4 GB. Half your GPU andOctane X PR7 Free Trial runs perfectly.
Question: Have you deleted all the other .xlib files for R19, S22 etc? My C4D & Octane would not work until I had only the one c4doctane-S22.xlib correct file for my version of Cinema4d
My stand-alone Demo Octane seems not to work. It runs but I can't open any .c4d files. I'm wondering if it works in a different way?
I'm buying the Studio (2 GPU) monthly subscription unless anyone off this forum tells me the Enterprise/RNDR (ultimate bundle) will render much faster on/with my iMac but I'm told by a mate it won't cos my iMacs a bottleneck, yet I don't understand how an iMac can slow network rendering?
Good Luck
ant...
you can find PR8 Standalone and plugins by visiting your personal Downloads area:
https://render.otoy.com/account/download_archive.php
You need to select your purchased version from the Select Software pop up:
To test Standalone, please open Standalone demo, right click anywhere in the node graph panel, and choose Materials/Metallic, to create the material node.
Now right click on the node and choose Render.
Then please share a screenshot of the Standalone interface thanks.
ciao Beppe
ljc199077
still got this problem in pr14 on my mac pro with w5700X+radeon vii
HERE is my log report link https://www.icloud.com.cn/iclouddrive/0 ... log_report
do you see a difference if you disable the AMD 5700 in Devices panel, and render only with AMD Radeon VII?
ciao,
Beppe
