"Use denoised beauty pass" Never ENDS
snaffy
If I select "Use denoised beauty pass" in the render settings the render will NEVER end...in ANY scene I try. Has anyone else experienced this? This is a brand new PC and I'm using C4D 23.110 and OctaneStudio-for-C4D-2020.1.5_R4_win
ATTACHED THE SCENE
test.zip
(47.5 KiB) Downloaded 122 times
snaffy
Tried another route...turned off the 'Use denoised beauty pass' and tried to save it as an AOV instead...Same result...render never ends...If I try to render with 'Denoised' at all it won't stop rendering (with my simple cube scene) What is going on here??
snaffy
Rebooted, re-installed C4D and Octane....(using a RTX 3080 BTW with driver 457.09) Same result...if I choose 'Denoise' for ANYTHING the render will never stop
Please upgrade to 2020.2-RC6, to be able to use Denoiser with new Ampere RTX 30X0 GPUs:
viewtopic.php?f=85&t=76633
ciao Beppe
snaffy
Thanks! Seemed to do the trick
