Rendering animation sequence only with film region selection
DannoKaBlammo
Is it possible to render out an animation sequence that only uses the film region square you can draw in the live viewer? The only workaround I've figured out so far is to save each frame manually using the file>save as command within the live viewer.
hi,
go to render settings/octanerender/main tab/render region, and click on the “get last region from lv” button:
DannoKaBlammo
Awesome, thanks!
