Object Tag & Constraint Expression NOT UPDATING
Sub forum for help and tutorials.
analog
Hey guys,
I´m working on a Robot Animation based on a Mixamo-Rig. The Base-Body is rigged and a lot of additional Parts are attached by constraint expressions. Everything works as expected and renders nice & fast.
By finishing the Project I enabled object motion blur in the object-tag. Now the constraint objects are not updating, not moving with the rigged mesh.
I searched the Web & the forum. I rendered the animation starting at frame 0. I attached the object-tag to the meshes within the Null with the constraint Tag. Force Update is enabled. Nothing works :cry:
I´m using the OctaneRender_Studio_2020_2_RC5 and the latest Plugin Version 2020.1.5-R5
Can anybody help?
System Specs
MB: Asus Pro WS X570-ACE
CPU: AMD Ryzen 3950x
GPU 1: NVIDIA RTX 3090FE
GPU 2: ASUS RTX 2080
RAM: Corsair Vengeance RGB pro 3200 4x16GB
OS: Win10 64bit
Cinema 4D R20
I can help if you put a sample scene.
analog
aoktar wrote:I can help if you put a sample scene.
Hey :)
the file is about 130MB. Is´s in my Dropbox but I can`t post the Link here
I can send It you private or I make a smaller dummyfile..
THX for your support!
System Specs
OS: Win10 64bit
Cinema 4D R20
Hey :)
Sample scene means that just leave related parts and send me by a PM, thanks
analog
aoktar wrote:
Hey :)
Just found out setting shutter alignment to Centered worked! :P
Only the rigged Mesh with Motionsystem is not working. Perhaps I should bake it in Alembic?
I´ll send you a PM
Thanks!
System Specs
OS: Win10 64bit
Cinema 4D R20
Return to “Help / Tutorials”
