I am getting more and more frustrated with the way Octane behaves in my setup. Even when I try the simplest scenes, try to follow really simple tutorials, I am getting constant crashes, and there seem to be no real repeatable scenario to the crashes. Often it is a application crash but also A crash with a warning that I should update my graphics driver.
I have been using X since the first prerelease and I can say that I see progress. The first PR's were really slow and it was almost impossible to use the node editor. I have the feeling that most of my crashes come from any manipulations in the node editor buty I could be wrong. I am using the PR 3 standalone version and the PR 6 plugin version. I am on Catalina 10.15.7
Thank You very much
Piotr
Octane X PR 6 and AMD RADEON RX 5700 XT
C. RAM Capacity (i.e. 6 GB)
- Attachments
- _BugReport.txt
- (364.51 KiB) Downloaded 204 times
- _BugReport.zip
- (27.22 KiB) Downloaded 173 times
- bugreport_20201226_163034.zip
- (1.61 KiB) Downloaded 212 times
iMac (Retina 5K, 27-inch, 2017)
4,2 GHz Quad-Core Intel Core i7
40 GB 2400 MHz DDR4
Radeon RX 5700 XT (external GPU Akitio Node)
40 GB 2400 MHz DDR4
- plasmapeppers
PR 7 is out with a plugin and standalone version if you upgrade to Big Sur 11.1 - it might have fixed the bugs you are talking about, so Id recommend trying that first.
CUDA
i7-7820X 96GB + 1080Ti
i7-8650U 16GB + 1060M
Metal
Mac mini i7-8700B 32GB + Radeon VII eGPU
Metal
Yes. I am planning to do that but some programs that I use are still not fully supported so I guess I have to stick with Catalina for a while.
Piotr
Piotr
40 GB 2400 MHz DDR4
40 GB 2400 MHz DDR4
