install problem
Houdini Integrated Plugin
olivierj
i have a problem installing octane.
I use houdini 18.0.566 and Octane_2020.1.5.0_Houdini_18.0.566_Win64
when starting i get [126] Couldn't load C:/Octane_2020.1.5.0_Houdini_18.0.566_Win64/dso/HoudiniOctane_18.0.566.dll. This is probably because this file was intended for use with a different version of Houdini
I tried Octane_2020.1.5.0_Houdini_18.0.566_Win64 and got the same problem.
Any idea of what i could do wrong ?
thank you
juanjgon
This can be a configuration problem, perhaps with the PATH variable in your houdini.env file. Can you please attach your houdini.env file to take a look at it?
olivierj
thank you for the answer, here is the env and below the houdini infos :
PATH = "C:/Octane_2020.1.5.0_Houdini_18.0.566_Win64/bin";$PATH
HOUDINI_PATH = "C:/Octane_2020.1.5.0_Houdini_18.0.566_Win64;&"
HOUDINI_DSO_ERROR = 2
Houdini FX Version 18.0.566
Operating System: Windows 10 Pro x64
Number of Cores: 32
Physical Memory: 95.90 GB
Number of Screens: 2
Screen 0: 1920 x 1200 at 0,0
Work Area 0: 1920 x 1170 at 0,0
Screen 0 DPI: 99.4
Screen 1: 1920 x 1200 at 1920,0
Work Area 1: 1920 x 1170 at 1920,0
Screen 1 DPI: 99.4
Build platform: windows-x86_64-cl19.16
Python Version: 2.7
Qt Version: 5.12.6
UI Scale: 1.000
OpenGL Vendor: NVIDIA Corporation
OpenGL Renderer: GeForce GTX 1080 Ti/PCIe/SSE2
OpenGL Version: 4.6.0 NVIDIA 452.06
OpenGL Shading Language: 4.60 NVIDIA
Detected: NVidia Consumer
11264 MB
452.6.0.0
HOUDINI_OTLSCAN_PATH //mumstorage/pipeline/houdini/config/plugins/qLib-master/otls/base;//mumstorage/pipeline/houdini/config/plugins/qLib-master/otls/future;//mumstorage/pipeline/houdini/config/plugins/qLib-master/otls/experimental;&;//mumstorage/pipeline/deadline/10/submitters/HoudiniSubmitter
HOUDINI_PATH C:/Octane_2020.1.5.0_Houdini_18.0.566_Win64;//mumstorage/pipeline/houdini/config/plugins/qLib-master;//mumstorage/pipeline/houdini/config/plugins/MSLiveLink/3.4.0;//mumstorage/pipeline/houdini/config;//mumstorage/pipeline/deadline/10/submitters/HoudiniSubmitter;//mumstorage/pipeline/redshift/3_0_30/Plugins/Houdini/18.0.566;C:/Prism/Plugins/Apps/Houdini/Integration;&
juanjgon
Can you please try this as a PATH variable?
PATH = "C:\Octane_2020.1.5.0_Houdini_18.0.566_Win64\bin;$PATH"
Return to “Houdini”
