OctaneRender™ for Blender 2020.1.5 - 22.2 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Upgraded to Blender 2.91
  • Supported the new volume modifiers(mesh to volume, volume to mesh, volume displace)
FIXES SINCE LAST RELEASE
  • Fixed string inputs in the OSL nodes
  • Fixed the issue that the startup file cannot include resources in the C driver
  • Fixed the redundant volume data update
  • Fixed deep image/render passes export issue
You can read about new features of OctaneRender™ 2020.1.5 here:
viewtopic.php?f=24&t=75704
1. OctaneRender™ Server
Windows
Blender Octane Edition - 22.2 (2.91)
Octane Server - Enterprise Edition - 22.2
Linux
Installation:
$ OctaneServer &
DOWNLOAD
macOS (CUDA)
DOWNLOAD
