Trying to figure out why octane crashes when launched via hqueue, hython or hscript as the "hquser" username.
[hquser@weeWhammy hfs18.0]$ cd /opt/hfs18.0 && source houdini_setup
The Houdini 18.0.597 environment has been initialized.
[hquser@weeWhammy hfs18.0]$ hscript
[Octane] Octane Render for Houdini. Build 2020.1.5.3 (Build date: Nov 5 2020 20:37:21)
[Octane] Octane API: 2020.1.5
[Octane] HDK API: 18.0.597
[Octane] Houdini host version: 18.0.597
[Octane] Initializing Octane API
14938 ThreadId=0x7fa6aebff700: Fatal error: Segmentation fault
-- TRACEBACK BEGIN --
Traceback from hbatch 18.0.597 (Compiled on linux-x86_64-gcc6.3):
stackTrace() <libHoudiniUT.so>
signalCallback(UTsignalHandlerArg) <libHoudiniUT.so>
UT_Signal::UT_ComboSignalHandler::operator()(int, siginfo_t*, void*) const <libHoudiniUT.so>
UT_Signal::processSignal(int, siginfo_t*, void*) <libHoudiniUT.so>
_L_unlock_13 <libpthread.so.0>
Octane::maxHosts(Octane::NetInterfaceInfo const&) <liboctane.so>
Octane::runFeaturesCheck() <liboctane.so>
Octane::ApiProjectWorkspace::getNodeGraphEditors() <liboctane.so>
Octane::ApiFileChooser::results() const <liboctane.so>
start_thread <libpthread.so.0>
__clone <libc.so.6>
-- TRACEBACK END --
14938: Fatal error: Segmentation fault (sent by pid 14938)
__pthread_cond_wait <libpthread.so.0>
Octane::apiMode_Shared_start(char const*, bool, char const**, char* (*)(void*), void*, bool) <liboctane.so>
HOctane_initAPI(bool) <Houdini_Octane_18.0.597.so>
ROP_Octane::getTemplates() <Houdini_Octane_18.0.597.so>
ROP_Octane::getTemplatePair() <Houdini_Octane_18.0.597.so>
newDriverOperator <Houdini_Octane_18.0.597.so>
UT_DSO::run(char const*, void*, bool) <libHoudiniUT.so>
OP_OperatorTable::runDSOInstall() <libHoudiniPRM.so>
OP_Network::getOperatorTable(UT_StringRef const&, char const*) <libHoudiniPRM.so>
MGR_Node::buildRopTable(char const*) <libHoudiniOPZ.so>
MGR_Node::initTable(MGR_MANAGER_TYPE) <libHoudiniOPZ.so>
MOT_Director::MOT_Director(UT_StringHolder const&, bool, bool) <libHoudiniOPZ.so>
_init <hbatch-bin>
__libc_start_main <libc.so.6>
_init <hbatch-bin>
-- TRACEBACK END --
I've added hquser to the "wheel" group as this is the way to give users SUDO privilege's in centos.
I've also chmod -R 777 /opt/Octane* so there shouldn't be any permission issues with octanes install path.
Do you know why this might be happening?
