How can I hide HDRI image from the render?
plazadelmar
OS X Yosemite | Geforce GT650M | i7 2.6 | 8GB
you can enable the Alpha Channel option in the Kernel settings, and replace the background in post, or you can use the Visible Environment node to replace the Background/Backplate, or reflections, and or refraction:
https://docs.otoy.com/StandaloneH_STA/S ... ht=visible
Then you can use the following OSL Projection node to match the Background image to viewport:
viewtopic.php?f=21&t=65575&hilit=osl+projection
ciao Beppe
