Hello,
Subject pretty much says it all. I have an Octane material for my base material, I have another octane material with a selection tag asigned to it. If i put the object in a cloner, the Live View doesnt show the material with the selection tag. If i dont use the cloner, it shows fine.
Cloner set to "Instance" or "Multi Instance" doesnt solve it.
Octane Material with selection tag in cloner not updating
A sample scene will be much appreciated. Use on/off on cloner for a workaround
- RSgraphics
Can i just send the scene to you? I cant post a project scene on the forum for everyone to see.
Edit:
Oaktar, i was chasing a rabbit down the wrong hole. It was a pure rookie mistake that resembled issues with textures and cloners.
OFF TOPIC:
do you recommend using C4D subdivision or the Octane Subdivision during rendering? Is one faster?
Edit:
OFF TOPIC:
Well no problem! Don't know which is faster. Export process will be shorter when you use Octane subdiv but api update will be longer. Make a test please
