i get this on the default octane blender scene whene i hit render.
i also get in every other scene. what does this mean?
Tried to access pin via an invalid ID P_UNKNOWN (0)
Tried to access null node pin
Can't read bool from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFB16907280)
Tried to access pin via an invalid ID P_AI_LIGHT_STRENGTH (385)
Can't read float from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFB16907280)
Can't write float to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFB16907280)
then it goes on with:
Could not refresh authorization token. Will retry in 60s
strange log reports
for anyone stumbling across this - i have reinstalled server and blender and now the authorisation issue is gone.
the other logs are not an issue according to support.
the authorisation issue seemed to be the main culprit of the issues i was having with blender (slow rendering, inconsistent render time) and i will update the other posts i made.
- linograndiotoy
Thanks for letting us know! I'm happy you solved your issue!
