Render queue
MickBe85
Hi All
I'm pretty new to Octane and I'm loving it so far. I use to work with Keyshot, which lets you render different camera angles In queue in a very simple and organized way.
I'm working on a scene in I need 4-5 different angles.
Is there a way to set up a render queue, so all camera angles will render on after the other, or can I use Cinemas build in render queue somehow?
Cheers.
you can use the C4D render Queue option anso with c4doctane, but it is not very efficient in this case, since you need to reload the entire scene at each frame.
If you need 4/5 different views of the same project, it makes more sense to use the c4d Stage object, and animate the Camera assignment for the first 4/5 frames, or use the Take system to save different takes/views, to render them all at once in Picture Viewer with the proper command.
ciao Beppe
