Dark Shadow Issue?
jmilton
I'm a new convert from Lightwave where I used Octane before moving to Maya. I'm see this issue when setting up a scene in Maya. I'm seeing this dark 'shadow' that changes when I move the camera position. I get the same 'shadow' if I change the Kernel type.
I'm using HDRI image for the background and Octane Environment. The odd thing is this didn't show up when I set up the scene but after I saved the file, rebooted and reloaded the Maya scene the 'shadow' shows up.
Thansk,
Jeff
BK
jmilton wrote:Hi,
Thansk,
Jeff
Hi Jeff,
Thank you for the post.
Could you please share the scene here or via PM for us to take a quick look?
Cheers
Kind Regards
bk3d
jmilton
Hi BK,
Thanks for taking a look. I included all textures I used so the .rar file is large. I put it out at this OneDrive location. Let me know if you can't access or you need other files.
https://1drv.ms/u/s!AiKS6LJ0blRShIBdobw ... Q?e=WWWWmi
Jeff
BK
jmilton wrote:Hi BK,
Jeff
Hi Jeff,
Thank you so much for sharing the scene file.
Would you please try re-link the Normal map and roughness texture path from the Hypershade and see if it works?
For some reason, these two textures were not loaded maybe it's best to work setting as Maya project.
cheers
Kind Regards
bk3d
jmilton
HI BK,
Thanks for the help. The problem was with the Normal map node. Removing the normal node link and re-connecting didn't work. I had to delete the Octane Image Texture node in Hypershade, re-add a new one then add back the Normal map for the brick wall.
Jeff
BK
jmilton wrote:HI BK,
Jeff
Thank you Jeff!! Glad to hear it's working now :)
Cheers
Kind Regards
bk3d
Return to “Autodesk Maya”
