OctaneRender™ for Blender 2020.1.5 - 21.15 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Upgraded to 2.83.7
  • Upgraded to 2020.1.5
FIXES SINCE LAST RELEASE
  • Fixed aperture DoF when using an orthographic camera
  • Fixed view layer rendering issue under animation final render
  • Fixed Round Edge node connection issue
  • Fixed the wrong node list for the Transform input of a Projection node
You can read about new features of OctaneRender™ 2020.1.5 here:
viewtopic.php?f=24&t=75704
1. OctaneRender™ Server
Windows
Blender Octane Edition - 21.15 (2.83.7)
Octane Server - Enterprise Edition - 2.83.7
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX
DOWNLOAD
