Will the RTX 3080 work in Octane 4.05-R7?
Maxter
Hello guys,
will the new RTX gpu from Nvidia be supported in the Octane version 4.05-R7? I couldn't finde any articles about this version with this gpu.
Do I have to upgrade to Octane 2020? :|
Best regards
Maxter
Octane for Cinema 4D
5950X | 64 GB 3600MHz DDR4 | 2x 3080 RTX 10 GB | 1200W PSU
whersmy
I`m on 4 also...I think we will need to upgrade.
Octane 2022.1.1 nv535.98
x201t - gtx580 - egpu ec
jimho
version 4 is not supporting RTX, which is the RTX 3080's big advantage...
It will need to be at least version 2010.1.5 which start to support RTX 30 seris
Supermicro 4028GR TR2|Intel xeon E5 2697 V3| windows 10| revit 2019 |Titan V+ Quadro GV100+RTX 2080 Ti
Maxter
jimho wrote:version 4 is not supporting RTX, which is the RTX 3080's big advantage...
But will it work without RTX?
Grafikdust
Can someone from Otoy please answer this question?
I really don't know why this information isn't already available for your costumers.
thank you
Maxter
Grafikdust wrote:Can someone from Otoy please answer this question?
thank you
I reached out to the support and the anwser is yes but you can't use the RTX acceliration :/
Grafikdust
Thank you, Maxter!
That's good to know.
libradesignidiot
Understand that the support team had replied RTX 3080 work in Octane 4.05-R7, but just want to ask if anyone actually using RTX 3080 with Octane 4.05-R7? I saw from another post in the forum said the AI Denoiser will cause issue when render, just want to make sure if it works fine without using AI denoiser in Octane 4.05-R7. Thanks!
The issue with RTX 30X0 GPUs has been solved in 2020.2-XB4 SDK:
viewtopic.php?f=33&t=76077
So we need to wait for c4doctane 2020.2-XB4 to have the full RTX 30X0 support.
In the meantime, if you need to render with AI Denoiser active, you should need to export your scene to Standalone 2020-XB4 in .orbx format and render from there.
ciao Beppe
salvation
just got a RTX 3090 and Octane 4.05 is not working. :(
It shows me in the preference:
CUDA version: 11.10
Device: Gefroce RTX 3090 (compute model 8.6)
But at the bottom of the Viewport stands in red "no CUDA GPUs"
How can I now render my old Standalone files?
Win7 64 | Geforce 470GTX 1280MB | Q9550 2.83GHz | 8GB Ram | NVidia 306.23 , Cuda 5.0.1
