Octane 2020.1 For Unreal Engine - v0.40
Moderator: ChrisHekman
ChrisHekman
Octane for Unreal Engine 0.40
Changes: Fixes:
  • Fixed issue with subdivision not being set for materials with displacement
  • Fixed texture copy crash
  • Fixed material switching and removing issues on landscapes
UE 4.25
Studio Installer: https://www.otoyserver.com/unrealengine ... UE4_25.exe
Enterprise Installer: https://www.otoyserver.com/unrealengine ... UE4_25.exe
Free Version Installer: https://www.otoyserver.com/unrealengine ... UE4_25.exe
UE 4.24
Studio Installer: https://www.otoyserver.com/unrealengine ... UE4_24.exe
Enterprise Installer: https://www.otoyserver.com/unrealengine ... UE4_24.exe
Free Version Installer: https://www.otoyserver.com/unrealengine ... UE4_24.exe
UE 4.23
Studio Installer: https://www.otoyserver.com/unrealengine ... UE4_23.exe
Enterprise Installer: https://www.otoyserver.com/unrealengine ... UE4_23.exe
Free Version Installer: https://www.otoyserver.com/unrealengine ... UE4_23.exe
EvolverInteractive
Thanks Chris for all the updates.
PeterBikki
Hey Chris,
What's your plan of releasing Octane for Unreal 4.26? I assume you wait until it gets out from preview releases.
ChrisHekman
PeterBikki wrote:Hey Chris,
That is the plan yes.
oisilener1982
May I ask if RTX 3080 is working in this version?
Renbry
Hello,
Are there any plans to translate Virtual Textures in the newer versions of UE4 ?
I've started using them for the benefits of 8k+ resolution but also because of the UDIM compatibility.
See here for an example I'm putting together for virtual production conversations : https://www.youtube.com/watch?v=2DlLwg7 ... e=youtu.be
There's almost 100 8k textures loaded onto tiled geometry in only ~9 materials and while i could have 100 materials it wouldn't justify the setup time in doing so.
As I push further into this area it'd be great to be able to render in Octane whereas at the moment Unreal crashes as it tries to convert the textures.
Thanks!
Matt Hermans
Electric Lens Co.
ChrisHekman
oisilener1982 wrote:May I ask if RTX 3080 is working in this version?
It should yes.
oisilener1982
https://ibb.co/CJZBZBx
Octane for Unreal does not Render even if I wait for a Long time (Link Above)
Unreal Engine 4.25
Windows 10
It is working Fine in OctaneBench
Assertion failed: GPackageLoader.Get() [File:D:/Build/++UE4+Licensee/Sync/Engine/Source/Runtime/CoreUObject/Private/Serialization/AsyncPackageLoader.cpp] [Line: 500]
UE4Editor_Core
UE4Editor_Core
UE4Editor_CoreUObject
UE4Editor_RenderCore
UE4Editor_Engine
UE4Editor_Engine
UE4Editor_UnrealEd
UE4Editor_UnrealEd
UE4Editor_OctanePluginEditor
UE4Editor_Core
UE4Editor
UE4Editor
UE4Editor
UE4Editor
UE4Editor
kernel32
ntdll
ChrisHekman
Renbry wrote:Hello,
Thanks!
Matt Hermans
Electric Lens Co.
Virtual textures are difficult to translate in a meaningfull way to octane. All I can do is copy all the 8k textures, turn on out-of-core rendering.
ChrisHekman
oisilener1982 wrote: Octane for Unreal does not Render even if I wait for a Long time (Link Above)
Unreal Engine 4.25
Could you provide the octane logs?
- Go to the unreal main toolbar
- Click the octane dropdown arrow and select "OctaneGUI"
- In the OctaneGUI, go to windows and select "Create log window"
