OctaneRender™ for Blender 2020.1.5 - 21.14 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Upgraded to 2.83.6
  • Upgraded to 2020.1.5
  • Supported multiple reroute nodes
FIXES SINCE LAST RELEASE
  • Fixed image sequence update issue under viewport rendering
  • Fixed baking camera rendering issue
  • Fixed the traceback when adding blender preset configuration
  • Added the view layer name to the end of the exported filename(do not add the view layer name if it's the default)
You can read about new features of OctaneRender™ 2020.1.5 here:
viewtopic.php?f=24&t=75704
1. OctaneRender™ Server
Windows
Blender Octane Edition - 21.15 (2.83.6)
Octane Server - Enterprise Edition - 2.83.6
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX
DOWNLOAD
