can't move light locked in camera mode
Houdini Integrated Plugin
Ebo
Hi, I can't move light locked in camera mode when IPR is running. Houdini 18.0.499, Octane_2020.1.5.0_Houdini_18.0.499_vr_Win64. Thank you.
CNA101_Lymph_Node_02_JV.rar
(113.36 KiB) Downloaded 165 times
juanjgon
Hmm, I also get the message in the viewport (that to be honest, I don't know what it means), but in any case, I can move the light without problems, and the light position is updated in the IPR. Doesn't it work in your case?
Ebo
NO still have that problem. Now I also have laggy behaviour when I am adjusting gradient tool (very laggy) and use to be ok. Is there any chance it may be due to some settings? The laggy behaviour with gradient is continuing even when I Pause the IPR. It only works fine when I turn off the IPR. Any suggestions? It is really annoying :DD
Ebo
I turned off "Debug" and it is flying now again...
juanjgon
Ok. Yes, the problem can be that Octane was writing a very long log file or even worse, dumping it to the console. The log only must be enabled for debugging purposes, especially the log to console, which is really slow on Windows.
Ebo
I am so happy now. I don't even know how I turned that on.. :)
Return to “Houdini”
