Can't change out of core settings :\
gsfcreator
So, I'm having this strange problem with my main pc.
this one runs on a perpetual V4 and gets memory error messages when I try to render a scene that works perfectly fine on my second pc (subscription).
both computers got 1080TI + 32GB of RAM.
The second pc got out of core RAM usage limit set to 8.
on the first pc - it's stuck on 0. I try to change it to 8 (as it used to be) - but the change won't stick after I click save.
I also tried re-installing the plugin from scratch, and deleted the config.xml file, to no avail. any ideas?
Core I7-8700K, 32RAM, GTX1080Ti, win10
Hi. As per my last response to you via the help desk system....
You could try reversing the plugins - so install the Octane 4 version on your Octane 2020.1 Poser machine and vise-versa. They would then indicate if it's the Octane 4 version of the plugin at fault, or your PC.
Return to “Poser”
