Octane X not working on Macbook Pro Intel iris 655(GT3e) GPU
glossyliquid
Im using Octane X on Macbook Pro Intel iris 655(GT3e) GPU, it showing me there is no gpu device which is selected, but there has my gpu option in octane setting menu and it didn’t work plz help!
your Intel GPU is not currently supported by Apple Metal driver, you should need an eGPU box TB3, with AMD Radeon VII or 5700XT inside, to be able to use OctaneX now.
More AMD/Intel GPUs are going to be supported, by the next Apple Metal driver major update.
ciao Beppe
roandb
So would I also not be able to run Octane on a 2014 Mac mini with Intel Iris 1536 MB? I have it running Catalina smoothly but I assume I need a newer GPU?
Also what Mac Mini would be capable of running of Octane on Catalina?
We are expecting to have the full Metal support of Intel/AMD GPUs in the upcoming Mac Os 11 Big Sur, but I’m not expecting great performance from Intel GPUs :roll:
AMD GPUs are definitely better, in my opinion.
At the moment, only the following AMD GPUs are supported in OctaneX under Mac Os Catalina 10.15.6:
- Radeon Pro Vega II Duo - 412 OB*
- Radeon Pro Vega II - 206 OB
- Radeon VII - 200 OB
- 5700 XT - 170 OB
- Vega FE - ~161 OB
- Vega 64 -~148 OB
- Vega 56 - ~117 OB
- Vega 48 - 108 OB
- 5600M - 108 OB
- 5500M - 77 OB
- 5300M - ~nb
- Vega 20 - ~50 OB
- WX9100 - ~ nd
So you should need to add one of the supported AMD GPUs in an eGPU box connected via Thunderbolt 3, natively supported in Catalina, in order to be able to use OctaneX on your Mac now, like a Radeon VII or 5700 XT.
I’m using this solution for my iMac 27” 5k 2017, and it is working great!
Here are a couple of eGPU solutions used by other Mac Octane users:
https://www.sonnettech.com/product/egfx ... y-box.html
https://www.razer.com/gaming-laptops/razer-core-v2
https://www.akitio.com/expansion/thunder3-pcie-box
*the last solution needs an external PSU to work, as explained here:
viewtopic.php?f=9&t=43439&start=170#p276341
For Mac Mini 2014, you need to also purchase the Apple Thunderbolt 2 to 3 adapter:
https://www.apple.com/shop/product/MMEL ... -2-adapter
ciao Beppe
abo3eloa
hi
now Octane X pr2 It was released
I have MacBook Pro 2018 it has Graphic Cards
Radeon Pro 560X 4 GB
Intel UHD Graphics 630 1536 MB
Does this copy support the this cards?
It should, but you need to install Big Sur Beta, to have the latest Metal driver that supports Intel Skylake, and AMD Polaris GPUs.
ciao Beppe
qhrister
i have a macbook pro with a intel iris plus graphics 655, catalina OS and C4D r23. Is it possible to to run? Because atm im getting the error message "there is no GPU device witch is selected..."
Intel GPUs are supported only in Big Sur 11.
Catalina 10.15.7 does not have the correct Apple Metal driver.
You need an Mac from 2016 or newer, with Intel Skylake or newer CPU/GPU.
ciao Beppe
KingsJiang
Hi, I am having the same problem (after 2 years of the original post). I am receiving the same error massage, and I am running OctaneRender Cinema4D on Macbook Pro (13', 2018) with a similar GPU (Intel Iris 655 1536MB), but on macOS Monterey. Is it still not supported? Is there any way I can make it work? Thanks!!!
Unfortunately old AMD GPUs and Intel GPUs are not supported anymore in new OctaneX PR12/13/14 for macOS 12 Monterey - there were some Apple Metal driver related issues.
You should need to go back to Big Sur 11.6.6, with OctaneX PR11, but it must to be said that Intel GPUs are not the best in terms of rendering speed, they are the slower GPUs you can have, and they also have issue with material previews in PR11.
This is why they are not supported anymore.
ciao,
Beppe
