OctaneRender™ for Blender 2020.1.4 - 21.13 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Upgraded to Blender 2.83.5
  • Enhanced Orbx Preview feature
    • Added "External Alembic" Orbx Preview Type to support animated Orbx preview
    • Fixed Orbx Preview issue when dealing with relative file paths
    • Fixed some other issues in the Orbx Preview
  • Enabled Cycles OptiX support
FIXES SINCE LAST RELEASE
  • Fixed hair motion blur when rendering the object with varied hair number
  • Fixed the rendering issue when using the linked collections with the same name
  • Fixed octane sphere primitive attributes issue when dealing with alembic sequence
  • Disabled the "Prefer tonemap" option during rendering(it cannot be changed after render setup)
  • Fixed the painted texture update issue
  • Fixed the reroute node issue
  • Fixed the typos in the Specular Material
You can read about new features of OctaneRender™ 2020.1.4 here:
viewtopic.php?f=24&t=75421
1. OctaneRender™ Server
Windows
Blender Octane Edition - 21.13 (2.83.5)
Octane Server - Enterprise Edition - 2.83.5
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX
DOWNLOAD
