Plugin buttons throw errors. Using H18.0.532 with O2020.1.4
Houdini Integrated Plugin
jdinh
Has anyone ran into issues installing Octane for H18.0.532? I've added the Octane directory to the Houdini path. The tabs show up in the Houdini UI but selecting anything throws a unknown command error. Example error screenshot attached. Also should mention I am using Linux.
Any help appreciated, thank you.
Screenshot from 2020-08-27 02-18-52.png (15.07 KiB) Viewed 1990 times
juanjgon
This seems a configuration issue, probably a problem with the houdini.env file PATH variable, that must point to the plugin folder "bin" directory.
jdinh
Ah no dice. Adding the bin directory to the HOUDINI_PATH makes it worse. The UI tabs no longer work. I am using Ubunto 20 and the install guide instructs to leave out the bin directory in the path.
jdinh
OK I resolved it. Found another thread where you instructed the user to install freeglut lib, so thanks!
juanjgon
Yes, sorry. This lib is missing is some of the latest Linux distributions, so you need to install it to work with the plugin.
Return to “Houdini”
