Constant crashes when working with materials
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
kartata
iMac Pro 10-Core
macOS 10.15.6
Radeon Pro Vega 64 (16 GB)
64 GB RAM
Octane X PR1 for C4D
Cinema R21.207
Hey guys,
I get constant crashes when working with materials in Octane. Sometimes it's the adjustment of a noise slider, sometimes it is the connection of a transform node – could be anything.
In this specific case I just rearranged the nodes. The materials consists of several 8K textures. I already tried the 2K version of the textures – same results. Would be glad if you could help me.
c4doctanelog.txt
(61.9 KiB) Downloaded 198 times
bugreport_20200820_091305.zip
(1.78 KiB) Downloaded 169 times
Find bugreport.zip and post please. Your report has nothing useful.Also try it with PR1.1
kartata
Attached you find _bugreport.zip.
I can't find the PR 1.1 for C4D in the download section. Only standalone.
Thanks!
_BugReport.zip
(84.6 KiB) Downloaded 191 times
Could you check the stability when opengl/material previews are disabled?
kartata
It seemed a little more stable until i introduced a C4D noise. Then it immediately crashed.
I attached the bug report for this incident as well as an example scene file with the 2K version of the material.
Thanks for trying to help!
Crash_file.zip
(26.14 MiB) Downloaded 204 times
_BugReport.zip
(84.06 KiB) Downloaded 201 times
Return to “Bug Reports”
