Octane X™ PR 1.1
abstrax
Hi all,
This is a bugfix update of Octane X that fixes various issues that have been reported for PR1.
Changes since Octane X PR 1:
  • Fixed a potential hang caused by corrupted geometry data if texture displacement is being used.
  • Fixed a potential hang if UVW transform textures are being used.
  • Fixed a potential hang if deep image rendering is enabled, but no deep image passes.
  • Fixed incorrect loading of extra UV data if primitives actually don't have extra UV sets.
  • Fixed inverted logic of the polygon side texture.
  • Fixed artifacts produced by stacking multiple GGX lobes together with low roughness.
  • Fixed dirt node not being used with medium nodes (when there's actual surface intersection crossing the boundary of the medium).
  • Fixed composite material not updating while changing some child material's float data (non texture pins).
  • Fixed rendering of vertex attribute textures.
  • Fixed UV mapping of light sources on quad lights.
  • Fixed self illumination on quads, and illumination on the back of parallel surfaces in close proximity.
  • Fixed render error if an emitter has size 0.
  • Fixed incorrect rendering of tiled images where tiles with the index have no image assigned to.
  • Fixed incorrect rendering of the marble texture as greyscale if power input texture is not greyscale.
  • Fixed a memory leak that became significant when you load complex projects from ORBX files.
  • Improved out-of-core memory management when resources become scarce.
  • Standalone: Fixed very long scene load times when --no-gui is being used.
Download
Downloads for Enterprise subscription users:
Octane X Enterprise Standalone for MacOS
Octane X Enterprise Network Rendering Node for MacOS
Downloads for Studio subscription users:
Octane X Studio Standalone for MacOS
Demo downloads:
Octane X Demo Standalone for MacOS
Happy rendering
Your OTOY NZ team
caseyhupke
Trying to find the plugins, have they been released somewhere?
JoGo23
caseyhupke wrote:Trying to find the plugins, have they been released somewhere?
Same question for Modo plugin.
Goldorak
they will be shortly - it takes time to build for macOS 10.15+ due to plugin notarizarion process.
caseyhupke
Any update on this? Could really use them attributes.
JoGo23
Goldorak wrote:they will be shortly - it takes time to build for macOS 10.15+ due to plugin notarizarion process.
Any progress ? Or are you facing unexpected difficulties ?
DERJUNG
Sorry to say that, but because of the not following information I did not renew my subscription. If Apple's Notarization is really going so slowly, I will reconsider the usage of Octane X.
I am still waiting for a working plugin for Modo. I know it is a Beta, but it seems nobody here seems to have correct answers.
MacPro 12 [email protected] Ghz - 48GB 2933Mhz DDR4 - AMD Radeon Pro Vega II Duo 32GB
