How to Render out a sequence from Sequencer
Unreal® Engine Integrated Plugin
Moderator: ChrisHekman
Kalavathy
Hi Chris, I am new to Octane-Unreal and i am using free-tier. I couldn't render out a sequence from sequencer to disk. I have searched the forum and documentation and followed Solomon Jagwe's renderinganimated sequence tutorial, I have selected OctaneRenderTarget Actor and changed the ImageOutputFormat to Octane Render(Image). When i click Capture movie Movie Render Preview Opens and it renders the 0-th frame even though i have used Custom Start Frame as 12. The Camera seems Offset. It shows 100% at 0-th frame and no image is saved to disk and it shows Capturing video for long time. I even reduced the samples to 16 to fast check the rendering, same result. Can u guide me to render out a sequence out of sequencer.
Thanks.
ChrisHekman
1. Can you share your full sequencer settings? (The window with ImageOutputFormat in it)
2. Are you using the lastest version of the plugin? (viewtopic.php?f=132&t=75521)
Kalavathy
I am using the latest OctanePrime0_39_UE4_25.
EvolverInteractive
Super easy fix, your "Camera Mode" need to be viewport and that's it
ChrisHekman
I just tried the same settings and it works. Would it be possible for you to share your project with me? So i can check what is going on?
Kalavathy
ChrisHekman wrote:I just tried the same settings and it works. Would it be possible for you to share your project with me? So i can check what is going on?
Sure Chris. Projects Size is 677MB. I am new to this forum and I dont know how to attach it here. Is there any options available in this forum to send files.
ChrisHekman
you can email me at [email protected]
Return to “Unreal® Engine”
