[Plugin] Viewer node for Octane shaders
AiSatan
Hi, I'm new here and I can be alone who need this, but.
I noticed that node wrangler not really work with octane shaders. Main thing I use is the "viewer node" in shader node editor, I didn't found any alternatives, if you know one, please let me know.
I changed standard node_wrangler, so viewer node create diff shader if you use octande renderer, and work as usual (emission node) if you use cycle/eevee, so, I can use my classic blender and don't have conflicts.
Please be free to use this plugin as well if you need it.
Also, very important to disable standard node_wrangler, so it won't conflict. Because this is the same node_wrangler, just with changed viewer node.
https://github.com/AiSatan/node_wrangler_octane
installing and how it works:
Please, let me know if you notice any issue with it, I will try to fix it.
"Tomorrow happens either ways" #10363
linograndiotoy
Thank you for this!
Izzy-Cub
Like seriously, Thank you! This will smooth out the workflow a lot more.
animaion_1
Thanks!
Return to “Blender”
