Octane X hydra install crash
Hydra Solaris
filipw
I tried to install the hydra delegate for octane X but it doesn't work. (The regular plugin works in general but the intergration could be a lot better. I would understand if the future lies in the hydra version).
So, I get the hydra octane alternative to show up in the menu but when chosen, houdini crashes one way or the other, with this error message:
objc[13243]: Class CALayerObserver is implemented in both /Users/filip/Octane_OctaneX_PR1_Houdini_18.0.499_OSX/dso/liboctane.dylib (0x166e3de48) and /Applications/Houdini/Houdini18.0.499/Frameworks/Houdini.framework/Versions/18.0/Libraries/usd_plugins/liboctane.dylib (0x1d03a6e48). One of the two will be used. Which one is undefined.
objc[13243]: Class MacViewObserver is implemented in both /Users/filip/Octane_OctaneX_PR1_Houdini_18.0.499_OSX/dso/liboctane.dylib (0x166e3de98) and /Applications/Houdini/Houdini18.0.499/Frameworks/Houdini.framework/Versions/18.0/Libraries/usd_plugins/liboctane.dylib (0x1d03a6e98). One of the two will be used. Which one is undefined.
objc[13243]: Class MtlData is implemented in both /Users/filip/Octane_OctaneX_PR1_Houdini_18.0.499_OSX/dso/liboctane.dylib (0x166e3dee8) and /Applications/Houdini/Houdini18.0.499/Frameworks/Houdini.framework/Versions/18.0/Libraries/usd_plugins/liboctane.dylib (0x1d03a6ee8). One of the two will be used. Which one is undefined.
objc[13243]: Class XDRDisplayObserver is implemented in both /Users/filip/Octane_OctaneX_PR1_Houdini_18.0.499_OSX/dso/liboctane.dylib (0x166e3df38) and /Applications/Houdini/Houdini18.0.499/Frameworks/Houdini.framework/Versions/18.0/Libraries/usd_plugins/liboctane.dylib (0x1d03a6f38). One of the two will be used. Which one is undefined.
hindie(13243,0x1109f7dc0) malloc: Incorrect checksum for freed object 0x7ff12cf24258: probably modified after being freed.
Corrupt value: 0xdb4e1fe762e7f91
hindie(13243,0x1109f7dc0) malloc: *** set a breakpoint in malloc_error_break to debug
13243: (sent by pid 13243)
Please tell me how to fix this (and in the future, please make an installer that remove the possibility to do this wrong)
BK
filipw wrote:Hi,
Hi filipw,
Sorry for the late response!
Could you please try the beta II and let us know how it goes?
cheers!!
Kind Regards
bk3d
Return to “Hydra Solaris”
