Alembic sequences are not rendering
maciejfrolow
Hi all,
I have alembic sequences from Houdini which renders perfectly as still images (octane/open octane viewport) but NOT render correctly as a sequence when you specify a path to writing files and hit "animate".
The object seems to be translated to different coordinates and most of the time all the sequence is rendered with the first frame of the object. Seems like the bug is appeared when I moved to octane 4 plugin.
Here is a file which not renders: https://www.dropbox.com/s/g3x1917uqkgp3 ... 2.abc?dl=0
The problem exists even with an obj sequence using emReader :(
By advance thank you for any help.
M.
Best
Maciej Frolow
https://www.maciejfrolow.com
What version of the plugin are you using please?
Return to “Foundry Modo”
