OctaneRender™ for Blender 2020.1.4 - 21.12 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Upgraded to Octane 2020.1.4
  • Upgraded to Blender 2.83.3
  • Supported to export Deep EXR in the Octane Export Panel
  • Supported to use Blender Volume Object in Octane
    • Please use Blender Volume for OpenVDB from now on
    • The old way to use OpenVDB(Mesh data panel - Octane properties - Volume properties) will be hidden if it's not used in the files
FIXES SINCE LAST RELEASE
  • Add a "Maximize Instancing" feature(Octane Server - Maximize Instancing). When enabled, Octane will try to scatter instances as much as possible
You can read about new features of OctaneRender™ 2020.1.4 here:
viewtopic.php?f=24&t=75421
1. OctaneRender™ Server
Windows
Blender Octane Edition - 21.12 (2.83.3)
Octane Server - Enterprise Edition - 21.12
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 21.12 (2.83.3) Linux
Octane Server - Enterprise Edition - 21.12 Linux
macOS (CUDA)
DOWNLOAD
Blender Octane Edition - 21.12 (2.83.3) OSX
Octane Server - Enterprise Edition - 21.12 OSX
