vdb placement scale/axis/position
A forum for discussion, development and support, including subforums for discussion for various plugins for octane render and 3d the relevant animation packages
adriendupagne
2020.1.4
previous versions same issue.
Whenever I bring in a vdb sequence the scale but also the postinoing is always out of wack.
Plus the axis is way off.
XP generated vdb sequences.
its z-axis reverse. Apply some transform to fix it
adriendupagne
seems to be a bigger issue. VDBs are very unstable.
Stored on ssd.
VDBs drop out of project all the time and need to be relinked.
VDBs appearing huge distances away from location in XYZ space.
adriendupagne
confirmed with multiple users.
VDB sequence is positioning is completely broken.
VDB sequence keeps losing file path.
adriendupagne
Anyone got fix?
overthere
No fix, but I can confirm I see the same file path breaking issue with the Unity Octane version.
RTX2080, Win 10 64bit, 16GB RAM, AMD 1800X
Return to “Plugin Discussion/Support”
