NEW: Octane Hydra | Solaris plug-in beta [OBSOLETE]
Hydra Solaris (Legacy Plugin)
This plugin has been superseded by the Houdini plugin (2026.5.0.0 and higher)
BK
Dear Octane community,
OTOY® is proud to announce the availability of new DCC plugin OctaneRender Hydra | Solaris (V2020.1.3 - for Houdini 18.0.499) and Octane X Hydra | Solaris (PR1 for Houdini 18.0.499).
The world's fastest unbiased GPU rendering engine on CUDA and Metal now integrates completely with Houdini 18.0 Solaris.
What is Octane Hydra | Solaris?
The Octane Hydra | Solaris plugin is based on Pixar’s USD (Universal Scene Description) and Pixar’s Hydra API to empower artist workflows across look development, scene layout, lighting, and final rendering.
The Octane X release can be downloaded via Download page. Find out more about currently supported GPUs Octane X
Pixar's USD pipeline
https://renderman.pixar.com/stories/pixars-usd-pipeline
-Installation steps-
CUDAInstallation.txt
(1.12 KiB) Downloaded 912 times
MetalInstallation.txt
(930 Bytes) Downloaded 839 times
-Known Issues-
- Light Linker is yet to be supported as we are investigating if we could assign the Octane light IDs internally.
Enterprise Subscription Downloads
Enterprise Downloads
Studio Subscription Downloads
Happy GPU Rendering !!
Your team
OTOY
Kind Regards
bk3d
filipw
Seriously, has anyone on Mac been able to get this running?
I have tried to reach out on this forum, discord and finally to the help email but that is of over the weekend.
This is the installation text:
Octane Houdini Solaris Enterprise plugin install instructions
You should be running the version of Houdini which matches the plugin distribution.
If you want to see the Octane UI when the Octane renderer is selected in Houdini, copy
hdOctaneScenes to your Mac's home folder.
You can rename hdOctane.txt to disable the Octane SDK UI window.
The first time you render, the scene will be exported to hdOctaneExport.orbx in hdOctaneScenes.
Delete the hdOctaneExport.orbx file and relaunch Houdini to export a new orbx file.
Copy the contents of into_usd_plugins into the Houdini usd_plugins folder.
Example (change the Houdini version number):
/Applications/Houdini/Houdini18.0.499/Frameworks/Houdini.framework/Versions/18.0/Libraries/usd_plugins
Edit this file:
~/Library/Preferences/houdini/18.0/houdini.env
Add or modify this line:
HOUDINI_PATH = "/path/to/main_octane_plugin;/path/to/OctaneHydraSolarisEnterprise;&"
If I copy the contents of "into_usd_plugins" into /Applications/Houdini/Houdini18.0.499/Frameworks/Houdini.framework/Versions/18.0/Libraries/usd_plugins and set my HOUDINI_PATH to point to some random place where I put the whole folder "OctaneHydraSolarisEnterprise" the delegate will show up as an alternative in viewport but when choosen it crashes Houdini (or locks it up). The error seems to be that liboctane.dylib exists in two places. ( I should mention that the regular plugin works ok)
Anyway, those of you who have gotten this to work (on mac), would you please describe the steps taken?
BK
filipw wrote:Seriously, has anyone on Mac been able to get this running?
Edit this file:
Hi Filipw,
Thanks for reporting this issue.
We are working on resolving this issue ASAP!!
cheers
Kind Regards
bk3d
Phantom4
The installation text has since been updated as the copying step is no longer required since the main Octane Houdini plugin is included with the Octane Solaris distribution.
Instead just edit the Houdini.env file so that the combined plugin folder is used. This way both plugins share the same liboctane.dylib.
BK
Hiya,
Please find the latest releases from this link below:
viewforum.php?f=141
Cheers
Kind Regards
bk3d
Return to “Hydra Solaris (Legacy Plugin)”
