I recently upgradet from Version 3 to 4 and encountered some bugs:
1. When appending / linking a Material / Object from a Blendfile created in previous Version (3.07) the Material Inputs of the Mix Material gets swapped, which makes the Material look wrong.
2. When "Node Graph Upload Optimization" is enabled, changing Values "Ray Epsilon", "Path Term Power", "Coherent Ratio", "Caustic Blur" won't take effect after Preview Samples Count is reached
3. Ray Epsilon minimum Limit isn't the same as in Standalone. Pressing the arrow icons in the number field flips basically from min to max Limit without any intermediate steps.
4. GPU Memory Display in the Renderview Window is totally akward and wrong.
Bugs Octane Blender 4.05-16.6
C. RAM Capacity (i.e. 6 GB)
- linograndiotoy
With projects created in different versions that may happen.aufwind wrote:Even with the latest Version 21.11 linking / appending of objects / materials with
mix shader nodes don't work correctly.
